toolguy1964
- May 9, 2013
- 4
Newbie here....I have a 2002 Bluewater Breeze with a Volvo Penta 4.3L PEFS (Engine # 4012049644) with the VP SX Outdrive (SX-M 1.79). I would like to do a tune up and oil change on it as I'm sure it hasn't had one in a long time, if ever. The engine has 164 hrs. on it.
I am thinking of doing the following:
1) Change Engine Oil and Filter
2) Clean Carburetor
3) Replace Spark Plugs, Rotor and Cap
4) Replace Fuel Filter/Water Separator
5) Replace Impeller
I pulled one of the plugs to get the number off it (AC Delco MR43LTS). Does anyone know what the plug gap is for this engine? Also is there a better plug I should be using than an AC plug? Should I replace the ignition wires at this time? Should I also replace the out drive fluid? Is there anything else I should do to this motor/outdrive that I am missing?
Any advice would be greatly appreciated.
2) Clean Carburetor
5) Replace Impeller
