VP 5,0 FL -95
Badad
Has a Holley 2 port carb?
Interested to get more power. Will a 4 port improve power? How big rebuild are we talking about?
What about injection systems?
Anyone heard of NOx system on standard engine. What will that do and cost?
Dunaruna
Re: VP 5,0 FL -95
[colour=blue]Ain't no substitute for cubes.
You will spend thousands trying to gain 20, 30 maybe 40 ponies.
Laughing gas would be fantastic, just before the hull delaminated from the deck and the pistons headed for mars.
Silvertip
Re: VP 5,0 FL -95
4BBL carbs do little unless you use heads that can flow the extra air. Nitrous is good for a short blast such as getting on plane or in drag racing. Prolonged use would result in you need for a huge bilge pump as engine parts would likely try to find their way through the bottom of your boat and you would have copious amounts of water to get out of the bilge. An then there is the gearing in the outdrive and durability of the outdrive to consider. If you have a thick wallet, by all means go for it. Otherwise, you might want to consider trading for a boat with the performance characteristics you want.
