VP 5.0 GXI, Fuel Cell Replacement - Fuel Pressure Regulator Replacement
aperkov
I am replacing the Fuel Cell assembly on my 07' Chaparral, VP 5.0Gxi due to the dreaded whining noise and running issues both at idle and while running. My question is, do I need to replace the fuel pressure regulator as well or just clean it?
royston22
I just replaced the fuel cell. Didn't do anything to the pressure regulator. Motor is running just fine.
BigDeal3315
It is easy to pull and check the regulator once the system is depressurized. The screen on mine was plugged with black goo from paint inside the fuel cell. We blasted it clean with carb cleaner, and I ultimately did the e-clip modification specified in Volvo parts bulletin P-23-7 number 3, version 1. This replaces the screen with an e-clip spacer. I'd say it is worth checking.
