Hello!
This engine has a new water pump, new impeller, new stat and has been totally cleaned and mounted after installing new head gaskets. It is now working perfectly apart from temperature that doesn't stop going to its normal temp (just below 175) and back down to almost 100. This started after replacing the water pump back in August.
Volvo Penta replaced the original stat (140) with an 160?, may this be causing the problem? Should I try and get a 140?
I would appreciate very much if you could help me with this issue.
