Vp steering problems
Jgent
I have a Volvo Penta 5.0 has the sx drive. I found that there is a lot of play in the steering I looked it over and on the assembly the actuator part moves back and fourth about 3in in either direction before the arm begins to move the steering. I can hold it to o e side by hand and the play is gone. Is the normal or is the a fix for this
GA_Boater
I'll assume you're talking about a power steering ram mounted on the transom plate. Moving this into the V-P section.
Jgent
Yes it has what I think seems to be a lot of movement before it starts to catch and move the steering
Jgent
[No message]
First, why do you think there is lots of play.
Where are you measuring the 3" from
If your boat wanders a bit between idle speed and planing speed, that is normal....all v-hulls do that
Ayuh,..... The gap you show in yer pictures is the valve motion, when the motor is runnin', it'll self-center, 'n the gap will be consistent,.....
I'm guessin', as Scott says, yer experiencin' V-hull wander at idle speeds,....
