VP SX Drive | Torque Settings
baker556
Hello all,
Looking about the forum, found a couple of guide on the torque settings, can anyone else help me out filling in the last couple for when I take the outdrive off and inspect in the next couple of weeks thanks.
Drive is VP SX-M 2003.
PartPart NoTorque
Outdrive gasket drain plug3855081
Outdrive Gasket Fill3855081
Outdrive gasket dipstick3852045
Spark plug kit385185727 NM
Out drive locking nuts25 then 50 lbs | Pattern 6 3 - 2 1 - 4 5 (33 then 67 Nm)
Thanks
for your drain plugs/dipstick. they all get hand tightened with a screw driver. its just 3/8" threads in aluminum. in the neighborhood of 1 click on the wrist.
however if you really want to pull a toque wrench, in the neighborhood of 12-13 NM if metric, 95 in-lbs
