VRO fuel pump????
hannahbear
The fuel pump went bad in a 85 or 88 Johnson 200hp outboard. Can the VRO system be bypassed completely and a regular fuel pump be installed?? The VRO seems to cost a lot more and from what I understand had a lot of problems.......<br /><br />Thanks,
vinney
Re: VRO fuel pump????
You can buy a rebuilt vro for 100 bucks from dfi technology. The vro is the fuel pump and oil pump. They have a life cycle, you replace them and run them another 10 years. V
Rex
I would say. Just get a electric one put you<br />got to be able to set the pressure on it.<br />Rex
ob
hannahbear,This site has a fuel pump rebuid kit for your VRO.Also would replace air motor diaphragm. WWW.maxrules.com<br />If you choose to mix 50:1 the Vro fuel pump works fine as conventional pump.Just need to plug off oil half inlet and disconnect vro alarm wires.Good luck
DB.Beachum
you can change out the VRO for fuel pumps you would have to go to a PRE-VRO year motor 79-84 say,I change them out for offshore customers I do not like to use the VRO fuel pump,remember you have to pre-mix 1 pint to 6 gals,if you have a large tank it is better to do like was sugguested and replace the pump.
rickdb1boat
Advice given to me by another Member:<br /><br />
Rick,<br /><br />Are you going to physically remove the VRO pump, or just disable the oil injection function?<br /><br />If you're disabling the oil injection feature, that leaves the fuel pump portion of the unit in place.<br /><br />If you disable the oil injection feature, this is why you have to check things occasionally: <br />The design of the VRO unit incorporates an air motor, in which a diaphragm is driven by crankcase pressure and vacuum pulses. The air motor is connected via a stainless steel "rod" to a diaphragm style fuel pump and to a piston style oil pump. If contaminants get into the oil side of the pump, it may "jam" the oil piston in its bore. Since all 3 sections of the pump are interconnected by a "rod", the jammed oil piston will prevent the pump from functioning at all. Make sense??<br /><br />A premix conversion kit is a replacement "fuel-only" pump. It resembles a VRO (minus the oil pump section and alarm module). It costs about $100 less than a VRO and the beauty of it is it mounts in place and utilizes most of the same hoses the VRO did. This simplifies installation and the installer doesn't have to deal with fabricating brackets and ordering pre-formed hoses to retro-fit the old "house-shaped" fuel pumps. The retro-fit route is actually a little more costly in parts and labor. The premix conversion kit is the way to go IF and when the fuel portion of the VRO ever fails.<br /><br />-John<br /><br />
