Low oil alarm sounds when motor is first started. Oil tank is full. In order to make it quit sounding all I have to do is turn engine off. Then I can emediatly restart. Then it will do it again and I have to repete the process several times. Sometimes for thirty minutes or so. Engine also cuts off and I have to pump gas bulb to get started. This will also happin several times. After a while the motor will run fine the rest of the day. People have told me that it sounded like it was the VRO pump. I took it apart and cleaned it up and saw no holes or rips in either of the dioframes. Could the electronics in the VRO still be bad? What makes the pump work? Does it work off of vacume created by engine? Could there be a vacume line leaking? HELP! New VRO(5004558) is $269.
