i have a 84 evinrude 115.ill start with the vro pump first, the boat sat for about a month today i pumped prime ball geting ready to start motor i saw gas flowing out around the vro pump seal. should it be replaced or rebuilt and would it cause the motor to run different.when it was in the water at full throttle it sounded like it was running out of gas would start to fev up then bog back down. ok now with the over heat i have replaced rhe thermos and impeller.it would overheat only at wot. i started it today with the muffs on it ran for about 5 min ,i felt the water when it was peeing at first it was hose temp the it was hot as hell then hose temp and then hot again.within that 5min the overheat alarm came on. i put my finger on the head and could not hold it there for more than a sec.its only overheated on the water never with just the muffs any answers would really help.money is tight and a honest mechanic is hard to find
