hi guys i have a 1988 johnson 50 vro in very good order but i want to take the good advice from these forums and disconnect the pump and use premix. could someone please help me with step-by-step instructions on how to do it without causing any harm to the engine and so it can be reinstated if i should choose later. also the audible warning is shared by the waterflow/overheat alarm so obviously i don't want to interfere with that and i want the alarm check at start up to work also. your help is this matter will be gratefully received. tazzy.<br />p.s. i have looked at the other posts relating to this but none are comprehensive or specific enough.
