vro removal
jerkoz
was planning to remove the vro system on my 50 hp evinrude. went to the dealer to buy the plugs and wire harness plug to do the job and was told that i had to install a new fuel pump.i read that you could use the vro pump as the fuel pump after you remove the oil line and plug it.can anyone verify this?
clanton
Re: vro removal
Sure it will work, electrical tape for the wires, vacuum line cap from discount/autozone parts. If year model 1999 up, check the pulse hose from block to pump. The starter will wear a hole in pulse hose. Mix 50-1 oil/gas in tank.
