vro test
pajet
have 94 johnson 90hp ran last year premix 50-1 hooked up oil tank on first outing along with premix and used about 12 oz from tank while burning 4.5 gal of fuel.sound ok? also seems much better on fuel consumption. is this possible? where do the 2 wires from oil tank connect? thanks for all input.
Chris1956
Re: vro test
12 oz for 4.5 gal of gas is 48::1. That is pretty much dead on. The sensor wires from the oil tank connect to the harness that runs to the horn in the control or system check tach, which ever you have. One wire islikely ground, the other is signal.
wesley pipes
Re: vro test
there should be a plug under the cowling next to the other plugs for the controlls it is either a round plug or the square end with a brown and black wire
