dajohnson53
- Apr 28, 2004
- 1,627
Hi - I've posted before about this new to me low hours 1990 J200TXESM. The engine has always started very nicely and runs well at all RPMs. Although I've been running premix, I'm about to switch to clear fuel because the oil level in the tank goes down at the correct rate for fuel burning.
I've identified the pump as VRO2 by its fittings, etc. I've also - I think - identified the pulse limiter as probably the original old style black one and have purchased a new blue faced one.
The problem is: it looks like a bear to get at the thing to replace it. I'm thinking I have to remove many other parts as well.
Any words of wisdom about the easiest way to actually get at the pulse limiter to screw it out and screw the new one in? Thanks for any pointers you can give. I do have an OEM shop manual, but it doesn't have any step by step on this.
Related question: is this an "emergency" situation - is my engine in dire danger because of the old pulse limiter? If I continue to operate the engine (have put about 10 hours on it so far), do I need to be paranoid about the pulse limiter? If I'm worried, would it help at all to run premix in the tank, or is that irrelevant to the pulse limiter?
Thanks for any help you can give.
