does anybody know what the pressure and vacuum is to operate the pump? I have a vro2 pump on an evinrude 200, model VE200SLEID, The pump has been rebuilt and passes the bench checks.
Tested per flo chart for vro pump. Also checkedl output pressure.passed all these tests. Trying to measure the pressure/vacuum cycle to determine if the problem lies there, Thining bad crank seal or reed for the driving cylinder.
Worn skirts on piston will also cause this as crankcase pressure is to low to overcome spring in air motor. Will run on top end but will run out of fuel at idle...
