52Alumacraft
- Jul 26, 2007
- 29
I have an F90 with remote console and I would like to rig up a VTS switch. I assume the connector I need to get to is the one I have drawn the box around in the photo but was hoping someone could confirm that. It is a 3 wire connector (red, black, white) so probably black = common, red = up and white = down or the other way around. It has a plug in it. The plug has a jumper wire between two of the pins.
Anyone know of a source for Yamaha connectors and terminals? I have the switches I want to use and a cable but need the connector. I suppose I could buy the tiller VTS assembly and use only the connector but that would be a pretty expensive connector.
