"W" signal on Volvo B20 AQ130D
GlastronV174
Hello,
I've been looking all over the web for a solution but can't find it.
My 1973 Glastron V174 with Volvo Penta AQ130D has an alternator without a "W" connection.
I need this connection to feed to my new digital Wema Tachometer. The previous boat owner thinks
the signal comes from the coil, but at wich connection should I put the wire for the tach?
Many thanks!
Don S
Re: "W" signal on Volvo B20 AQ130D
Gas engines use the - terminal of the coil to signal the tach, not the alternator.
GlastronV174
Thank you Don. So connecting a wire from the - terminal on the coil will do the trick?
What ratio do you think the signal will be? As in; how many sparks/signals will be one revolution of the engine?
Thanks!
Don S
IO engines have used this method for ever. The tachs are usually set to the number of cylinder. You may have the wrong kind of tach.
