Re: wandering boat
Lyle;<br /><br />At slow speeds the bow is down, in the water, and will bow steer the boat.<br /><br />Keep in mind that the motor is your steering device (rutter) and the it is 20ft away from the bow tip. That is a long leverage arm to control. If the motor was mounted at the front (pulling the boat) there would be no wandering.<br /><br />The reason that the (side benefit to most people) Samrt Tabs reduce (almost eliminate) the wandering is that they are slightly down at this speed, mounted on each side of the boat, and resist the side to side movement. Although it is seldom the reason for purchasing tabs, nearly everyone comments that they are delighted to get rid of the anoying wander. (I call it the drunk test).
