- Sep 26, 2009
- 20,106
Boat: 2003 Crestliner 1650 SC Fish Hawk deep v
Motor: 2003 60hp 4 stroke Johnson
Prop: AL 14x17p(I believe it came with the motor when new. No model name)
Rated WOT rpm: 5300
Actual: 5300(maxed w/full load)
Want to accomplish: A better hole shot.
I know this is doable even tho it is a 4 stroke. I've proved it by adjusting boat setup. My main issue is weight distribution. It's tail heavy with the 4 stroke and boat design. Crestliner has since fixed the issue by relocating the tank, so I've heard. I have no weight to relocate. I don't want to use a hydro foil or tabs. I also don't want to add weight. I will lose my storage if I do. My hole shot isn't bad, therefore, I think it can be propped to accomplish my goal. If I put my daugher in the bow(all 3 of us in boat), or, just have me and her side by side it planes out good.(She's only 100# soaking wet). If all 3 of us are boating and she sits in the seat behind us in the center, I lose a decent hole shot.
Below are the OEM choices for my boat along with a description of each style, plus a layout of my boat(bottom of post. Pic is deceiving, it does have a 87" beam). I know this is info overkill, I just hope some of you knowledgable members will take the time to look it over.
Considering I'm currently at max rpm at WOT, one would think to go up in pitch, 19p. But, I don't want to make my hole shot worse. I "rarely" go WOT so if I exceed the rpms a little I can adjust at throttle.
I think the raker is out since I don't need more bow lift. I can barely trim it up as is without porpoising. Although, the bow will come out of the water more than enough as to not plow.
Right now I'm leaning towards the Viper 17P. What say you? Or, should I go to a completly different manufacturer?A huge thank you is an understatement.....
Stainless Steel: (For 60-70 hp 4 Stroke, 60-115 hp 3 cyl & V4, 40-90 hp E-TEC):
SST, Stainless Steel II Props:
# 175294 . 13.75" x 11" SST. Stainless Steel II Prop. -- (See also Hydrus # 177202). Triple Cup. For V-4 60-150 HP, Pontoon Boat... See also # 763300 and # 177202.
# 175013 13.75" x 13" SST. Stainless Steel II Prop. -- Triple Cup. For V-4 60-150 HP, Pontoon Boat. (Without triple cup blade, See P/N 392261). See also # 763300 and # 177202.
# 176571 13 7/8" x 15" Stainless Steel II Prop. -- (Same as P/N 389949). Swept Blade Design. For V-4 60-140 HP, 22-26 foot Cruiser boats.
# 176572 13.75" x 17" Stainless Steel II Prop. -- Swept Blade. For V-4 60-140 HP,18-21 foot Runabout boats.
This prop has been replaced by the Viper of the same size....
Viper Propellers:
# 177042 13-7/8" x 15"
# 176623 13-7/8" x 17"
# 763931 # 176624 13-7/8" x 19" - Swept Blade. For 16-19' Runabouts.
# 177261 # 176625 13-7/8" x 21" - Swept Blade. For 15-18' Light Runabouts.
RAKER Propellers:
For V4 60-150 HP, High Performance Bow Lifter,Bass Boat or High Performance Runabouts, Carbureted and Direct Injection E-TEC Models.
# 394758 # 763953 13.5" x 18" # 394759 13.5" x 20"
# 394760 13.5" x 22" # 394761 13.5" x 24"
SST - Stainless Steel Props: (Stainless Steel Tough)
- View Chart -
A Stainless prop will last longer than an aluminum prop, plus offers greater performance - beneficial for avid boating and water skiing. Has a "Thru-hub" exhaust and 3-blade painted stainless steel design. A low pitch propeller that comes standard double cupped, and is also available triple cupped for pontoon applications. SST props are repairable if damaged.
The SST propeller is 5 times stronger than an ordinary aluminum prop. The blades thinner are thinner for a cleaner bite to achieve higher top end speed. The SST is a fast planing prop with thru-hub exhaust and cupped blades. More expensive than aluminum, but highly recommended for the serious boater.
SST II:SST II---Double cupped blades on the SST II propeller let the user trim out more for greater speed. The outboard can be mounted higher for peak performance with less slippage then single cupped blades. With the SST II propeller, more MPH means more MPG. Boats go farther as well as faster on each gallon of fuel. Like the SST, the SST II propeller features super thin blades for cleaner bite and extra thrust; yet they're still 5 times stronger than aluminum.
RAKER Stainless Steel Props:
- View Chart -
3-blade propeller (highly polished), thru-hub, stainless steel prop with high blade rake to increase bow lift. For bass, runabouts or high performance boats. Ideal for boat applications over 50 mph in V-4 and V-6 Evinrude and Johnson outboard engines.
Rake is the measurement of the angle of the blade's tip toward or away from the gear case.
The custom cupped high rake blades provide superior bow lift and make your bass boat or high performance runabout plane fast and run fast. Made from aircraft quality stainless steel. The outer exhaust hub has drilled holes to ventilate the three highly polished stainless steel blades for more powerful acceleration.
VIPER Polished Stainless Steel Props:
- View Chart -
3 blade performance, high lustre finish - Made for speed!
Its longer swept blades and a larger diameter give this prop a better grip on the water, faster acceleration and greater top end speed. It's fast out of the hole and delivers maximum top end speed. Excellent on any recreational boat, from runabouts and cruisers to deck boats. A good choice for Evinrude Johnson V4 and V6 outboard engines.
Rated WOT rpm: 5300
Viper Propellers:
RAKER Propellers:
- View Chart -
- View Chart -
- View Chart -
