BigBabyLou
- Apr 9, 2002
- 129
If your bilge pump can be turned on by a switch and also a float, it is good to know whether your pump is running, right?<br /><br />What I did is: I had some spare illuminated switches which were almost the same size as the non-illuminated switches in the dash. I replaced my bilge pump switches and blower switch with the illuminated versions and now I feel more confident on the water, knowing when my pumps are on (and the blower too).<br /><br />El. explanation: your bilge pump has two wires connected to it, ground and 12V. The 12V wire is usually spliced somewhere at the pump and runs to the switch on the dash and to the float switch. If the float switch turns the pump on, the 12V will be also present at the switch on the dash which will illuminate the light and you will know your pump is running.<br /><br />Hope this helps someone the same way it helped me<br /><br />Have fun and be safe<br />Lou
