Want to rent a mercruiser hole template/drilling fixture
Jasonscott
Im looking to rent a mercruiser hole template/ drilling fixture. I am replacing the transom in my boat and I want to make sure i drill all the holes correctly. Im also swapping from the type 1 gimbal housing to an alpha one so all the holes arent in the correct spot anyways. Thanks alot!
Re: Want to rent a mercruiser hole template/drilling fixture
Ayuh,... I use a cut-out salvaged from an old aluminum boat to do the lay-out,...
Then drill freehand....
Some dealers have the jig,... call around...
Jasonscott
Im in wenatchee WA. I was going to originally do it freehand but was worried about getting the angles correct. Any input?
starsnstripers
NOPE! You need a template to go by. I used the transom of a junk boat, cut it out with a chainsaw and pealed the fiberglass portion from the plywood and whaa laa! You also need the measurement/spects on the height from the bottom of the boat.
starsnstripers
Why can't you use your existing Mercruiser cut out? I believe they are the same cutout. The one difference i think i saw once was the two center bolts might be in a different spot. If your replacing your transome save the cutout from it and match it to the newer gimble and that will show if their the same.
jasoutside
I'm right there with you on this (literally).
Jasonscott
I think u are exactly right. the 2 center studs seem to be the only holes that are not the same on the newer housing. I still have the holes in the fiberglass to go by, just not the 2 center ones.
starsnstripers
So line your old fiberglass piece up to the new gimble asy and make the correct holes in it.
