hi
i have a 90hr from new 4.3 vortec v6 with thunderbolt ignition and it has a merc 2 barrel carb. the year is 1999 of the motor.
the motor goes great and is in a hamilton jet boat driving a hamilton 212 jet unit. i would like sum more power,the boat
currently does 80kms and @ w.o.t and is pulling 4200rpm. im about to put a higher kw blade in unit to stop some of the slippage as i use the boat in river. with the new blade if i just put it in the motor will pull about 3500rpm. so i would like to bring the motor power up a wee bit.im thinking of buying a edelbrock manifold part number 2111 and a new holley 390cfm carb
which i have been told i should get about 30hp increase which i would be happy with. i may do a cam, but late next year im probably goin to sell boat and built a new boat with an ls motor so not to worried about a cam at this stage.
my question to you guys is do you see any problems with this size carb and is there anything i need to watch out for?
thanks for your help
