Lancer76
- Jul 23, 2017
- 121
My Warner Tachometer pegs when the power is applied it remains pegged whether the engine is running or not. However, the power must be on. When power is off, the needle drops to 0.
It used to operate correctly and then is was intermittent. Now it doesn't operate correctly at all. The power in and ground out wires are good, but i can't be sure about the inner connections. I removed the tach and measures the resistance from the power post to the ground post. There was no continuity at 20K ohm setting.
is that normal? I ask because the growing post turns freely in place but does not come out I'm wondering if that is normal.
FInally, my multimeter has a tach function and when hook it up I can measure engine speed with it. Maybe I have a bad analog tack it's 42 years old so I can't complain.
