with the do it yourself winterization kits. My dealer sold me on the idea this year so I gave it a try. I filled the bucket with 4 gallons of AF as per instructions and drained the block of all water and blew the hoses out with air. I opened the valve and started the engine and let it idle. I could see it coming out of the leg holes ok but it still was not coming out of the exhaust. The af was almost out so I turned off the engine. I then refilled the bucket a little more and started the engine again. I received the overheat alarm and immediatly shut down the engine.
I then hooked up a cold water supply immediatly and started the engine not caring about the af because I care about my engine more.
I ended up doing it the way I have always done it by pouring it down all the hoses.
I wasted 40 bucks on RV antifreeze and learned a strong lesson. I hope I didnt burn out the impeller. Will have to wait till next spring to find out.
For those of you who winterize with this kit, how much af is needed considering alot comes out the side of the muffs?
