Warning Horn Activates with key off
pbukowski
Hi,<br /><br />I have a 1984 90 HP Rude. Sometimes, when I turn the main power on, the warning horn continuously buzzes. The key is off. This happens when the engine is cold, in my garage, so it's not a temp thing.<br /><br />Any ideas as to what could be wrong. <br /><br />Thanks,<br />Paul
rickdb1boat
Re: Warning Horn Activates with key off
Try pulling the wire off the temp. sensor on the back of the head and see if it stops. Could be the horns failing, too.
kgw
Hi Tink,<br /> I had the same problem on 1986 rude,chased that prob. for 4yrs It was very intermitent and never in the drive way where i could trouble shoot . finaly failed completly. Turned out to be the electronic circuits in the oil tank pickup assembly. disconect the 2wire plug from oil tank see if it stops.
