Warning horn
elwilliams13
My warning horn on my 91 evinrude 225 broke and I have the newer 2 wire model horn without the grounding wire. It has the purple and the tan wire only. Is there any way to adapt this to my engine? It doesn,t work right now.
rodbolt
Re: Warning horn
hello<br /> but now you will no longer have a self test. now its imperitive to test the horn at least every 30 days.<br /> good luck and keep posting
seahorse5
Re: Warning horn
If your new horn has the 2 wires coming out of it (purple and tan) with a plastic connector on the end of them, then you have the WRONG one. That is for the 1996 and later System Check equipped motors.<br /><br />Your engine needs the warning horn with the short ground wire and 2 spade terminals on it.
Joe Reeves
Re: Warning horn
For a manual "Self Test" setup, simply run a wire from the TAN wire on the horn to a push button or self centering toggle switch terminal, and a wire from the other terminal of the button/switch to ground.<br /><br />Engaging the button/switch momentarily will cause to horn to sound, reassuring you that the horn is operational.
