bajabassboat
- Apr 3, 2007
- 18
I have a 86 johnson 150 J150TLCDC. VRO has been disconnected/ blocked off. I have been running 50:1 mix for a couple of years. Now all of the sudden I am getting an intermittent warning. It started after about 10 hours on the lake. I turn the boat off and it stops. start it back up and it good for a few hundred yards of Idle. I am on a no wake lake. I did put it in neutral and rev it and the warning tone turned solid like overheat but its spraying a great stream of water and doesn't feel overly hot. I put it back in gear and it starts intermittent again. Next time out if it happens I am goiing to pump the bulb and also disconnect the terminal to the vro / fuel pump connector and see if it stops. Any other ideas. Seems to run the same as always.
Thanks in advance!!
Thanks in advance!!
