warp plastic float bowls and a fix
johnson89
1989 90hp johnson.....My last 3-5 fishing trips my motor was getting hard to start,it would not idle very well,but would run good at speed.Then I notice what looked like a gas leak from around the float bowl..I had rebuilt these's carb.s about a year ago,so I thought maybe the screws were loose,so I pulled the carbs off and all was tight,that when I seen where these plastic float bowls would warp and had to be replace at over 110.00 each...after a little thinking I decided to sand the bowl level..I used 600wet-dry paper,layed the paper on a hard smooth surface and with the water running starting sanding slowly,after about 10 min.s of sanding,I place the bowl on a piece of glass and it was so flat and level I could not even slide a piece of papaer under the bowl,I checked all the way around an it was 100% flat...put it all back together fill the carbs up with gas and NO LEAKS at all.I let it set for 2 day and still a perfect seal.I hook up the muffs and the motor started on first try and idels very smooth.Took it to the lake today and same thing,started 1st try and idels very good,it has never startd this easy before I guess it has always had a very small leak or had been sucking in air and just got worst....this fix cost me nothing ,already had the sand paper,took me about 2-3 hours to compete the repairs..I guess time will tell if this fix is good,but so far it looks good...I tired to load a pic. but something has change on this site and can not load from computer.......
DargelJohn
Re: warp plastic float bowls and a fix
Nice post...I am currently running carbs with plastic bowls. No leaks yet, but I will definitely keep your fix in mind.
emdsapmgr
When those float bowls warp, not only can they leak fuel, but in some cases, the carb can suck air instead of fuel-and that can cause the running problems you encountered. Worse, if the carbs do suck air instead of fuel, that can result in a lean condtion which can cause major powerhead damage. Sounds like you've got things handled!
