Washer question
Dleopoldi914
I was greasing the steering cable and I lost this washer. I connected the cable without the washer. Can I easily get this washer in local marine supplier or do I need to order online?
also where are the grease fittings on my motor? My mercury engine has it listed in the owners manual. This engine doesn’t
the part number for the washer is whst you think ?
ahicks
For those that might be able to help, it would be much easier knowing what motor you have.
Washer would be available at a lot of hardwares that sell stainless steel nuts and bolts (Lowes, Home Depot, ACE, etc.).
dingbat
Commercial washer. 316 stainless. You might get lucky and find at big box store but doubt it. Local marine hardware or McMaster Carr on line
Dleopoldi914
Ok fixed the washer it was a 5/16. Tohatsu dealer told me. I have the m90a motor do you know where the grease fittings are ?
robert graham
Look in the area of the motor tilt and the motor pivot....that's usually where zerks are.....try tilting motor all the way up, as that may help to find and access them
