erikgreen
- Jan 8, 2007
- 3,105
Hi again everyone..
<P>
I've got the fuel tank out of my boat, and I've spent a few days cleaning out rotten wood and foam. See a pic here:
<A HREF="http://www.greendragon.org/boat2/P3201546.JPG">Tank out</A>
<P>
I decided after having to pull the deck over the tank, forward of the tank to the bow, and the two small bulkheads fore and aft of the tank, that I had best investigate the holes the PO left in the deck. For some reason (foam injection?) they cut a series of 1 inch holes in the deck, about 8 on each side. I used my new electric chainsaw to cut a 4x4 hole near four of the holes to check for water. <P>
I found that three of the holes have some dampness near the bottom. That sucks, obviously. It's not a ton of water, but it's some. I could grab a piece of foam from the bottom of the hole and squeeze out a few drops of water. Pic of the wettest hole:
<P>
<A HREF="http://www.greendragon.org/boat2/P3201550.JPG">Wet foam</A>
<P>
So, now my problem is, do I go all the way and put in a complete new deck? Or can I cut some drain holes, encapsulate them, and let the foam dry over time?
<P>
I'd say currently the stringers are in nice shape (they were encapsulated with resin) and most of the deck is very solid (tested with a crowbar) although slightly warped in places near those little holes.
<P>
I'm leaning toward needing to rip it all out and start clean (and get all that damn wet foam out) but I'd like to hear what you all think too.
<P>
Here's some more pics of the inside of my boat currently:
<A HREF="http://www.greendragon.org/boat2">Boat interior</A>
<P>
Erik
<P>
PS: You know, looking at my pics here I'm even more convinced I should pull the whole deck. It's not supposed to be shades of black like that, right?
<P>
<P>
<P>
<P>
<P>
<P>
<P>
<P>
Erik
<P>
