If using a water boot hooked to a hose, would it circulate enough water (if at all) if it has a bad impeller?
1963 Big Twin 40
Want to make sure it runs good enough to bother putting a new impellor in it. Speaking of which, how hard is it to do? And are other pieces of the pump usually replaced at same time? And if a screw from that cover dropped is taking lower unit apart only way to retrieve it?
Thanks in advance
1963 Big Twin 40
Thanks in advance
