Water bump .. the way it is or could be more!
eminentguy
Hi All,
I replaced the WaterPump in June 13, and last week, it started leaking again! so got replaced and found the bearing is bad because of the seal did let water in as it seems!
is it that such item should be replaced every 100 hours or so! or there could be a root cause or its just bad luck! just wondering.
I do allot of island hopping, but never went 'too Shallow', I have an in water fresh water flush system that I do not use as I usually run the boat every other day and think its not needed -maybe?-, could this be the reason?
Thanks as always...
Firas
ps. the engine is 5.8 OSXI-GF
Fun Times
Re: Water bump .. the way it is or could be more!
Hi there, is it the sea water pump (impeller) or the engine circulation water pump that keeps leaking?
eminentguy
it is the sea water pump ... btw, I checked the impeller after replacement and it is in a good condition still btw !
