Water Choke Parts
tamuben1
I have a 1963 johnson 75HP electric shift (v4al-15e) motor that I can find almost any part for, but I am having trouble finding parts for the water choke. Does anybody know where I can find parts for the water choke?
JB
Re: Water Choke Parts
Water choke?? Never heard of it. What is an alternate name for it?
F_R
He means the water heated automatic choke on the carburetor.
Do you have the part numbers you need? If so, try your local Evinrude dealer--you might be surprised at what's available. If no luck there, try www.sea-way.com
Not meaning to insult you, but if it were me, I wouldn't bother with it. Those things never worked when they were new. Most people just opened the door and manually choked it for a cold start, then put it in choke off position for the rest of the day. They only used the hot water choke for a few years, then went to a hot-air choke with electric booster that was much better.
tamuben1
Thanks. Good to know they never worked when they were new. I thought mine did not work because the motor had sat for 10 years.
