ready4itall
- May 4, 2015
- 49
Mercury 110 9.8hp
Short shaft, 2 stroke
Is water that is drawn from water pump and impeller all suppose to come out of tell tale? Or is some of the water released to lower unit?
I blew air into tell tale hose and water tube and on the other end felt little to no air. I gently blew water into tell tale hose to see little of it go out watee tube and majority of it going down the walls and surface inside driveshaft housing.
Is this normal?
Is this normal?
