Water Colled Voltage Regulator
bhammer
Ensign
Hi all,
83 merc 470/170hp. What is the water cooled voltage regulator for? I have seen many posts about this giving problems and the $$$ to replace it new. Is this soley for the charging system and if an upgrade to an altenator is done, do I need it? I have ordered a manual for this engine to read up and learn.
Thanks,
Brian
Reel Poor
Re: Water Colled Voltage Regulator
Yes, it is only for the charging system. If you were to upgrade with one of the aftermarket kits, which would include an alternator with a built in regulator, the original water cooled regulator would not be used.
Here's an example of a complete kit. 170 Conversion Kit
bhammer
Ensign
Thanks for the info. I plan to do the upgrade. Cheap insurance than being stuck in the water.
rodbolt
myself? I would simply maintain and run the OEM charging system until it failed, if it fails.
some did some did not as other things failed first.
its a rather pricey conversion and the worst thats going to happen is your going to look at the voltmeter oneday and realize its only showing battery voltage. from there an average sized battery in decent shape will continue for many hours of run time.
rndn
Welcome to the forum BHammer!!:):)
Reel Poor
I agree with rodbolt. It's hard to fix something that ain't broke. :p
TilliamWe
Banned
I would simply maintain and run the OEM ...
And when it does fail, I know a guy in Central FL that would sell the regulator to you for $150. It's used, but it works. (and he'd even throw in the complete motor too!)
bhammer
Ensign
Thanks guys for the feedback. The only concern is the fact of being stuck with a dead battery out in the middle of the water. :mad:
I suppose with a good battery and an hour or so of runtime if a failure occurs, that's good enough to get back to the trailer.:)
rodbolt
one of the biggest causes of regulator failure is loose wingnuts and bad battery cable connections, with the occasional loose nut behind the helm.
Coors
I always have a spare battery on-board.
