Water cooling problem for 1946-50 Johnson/Evinrude
todgil
I have a 5hp Eaton's Viking Gale twin outboard.<br />Model # C2G7<br />Serial # 00004353<br />I am not getting any cooling water through the engine.<br />I also noticed that there is oil in the water of the container I was using.<br />From what I can see,the water is drawn in from the prop and pumped from the prop up through the shaft to the water jacket and out.Is this correct?<br /><br />Now the oil I think is from the lower unit coming up from through the shaft into the water chamber.Is this correct?<br /><br />I dismanteled the lower unit and found the brass bushing to be worn oblong.The shaft is also worn.<br />Where can I find parts.
