Water deflectors - installation ('87 90HP Evin)
bang4dabuck
They don't seem to want to go in all the way. I even tried triple grease. What gives ?
Anything else I should do while I got the heads off ? Should I soak the heads in parts cleaner ?
I did not pull block. Did not break any HEAD bolts :Dand was left with 2 broken COVER bolts:( that I will have to drill/tap out (I got 4 other brokens out of head with heat and vise grips).
Dhadley
Re: Water deflectors - installation ('87 90HP Evin)
Don't use grease. After they're installed the may slip out of place easier. We spray them with something like Electra Clean or Brake Clean which evaporates. As long as the slot is clean they should just about bottom out. If it doesn't bottom out they'll only miss by a 1/16" or so and we trim that off flush with a razor blade. That depth varies a tiny bit between blocks as does the hose length.
Joe Reeves
(Water Deflectors)
(J. Reeves)
Water deflectors are actually lengths of 3/8" outside diameter rubber hose, installed between the top cylinder and any cylinder beneath it, and also between the bottom cylinder and the block. The purpose of the deflectors is to have the water follow a definite path around the cylinder walls. Unfortunately the deflectors between the cylinders will at times swell sideways due to either a previous bad overheating problem, or simply due to age and salt corrosion. This causes a water flow restriction which usually allows the water to cool sufficently at low rpms but not at the higher rpms.
This hose material can be purchased reasonably at any automotive parts type store if you care to make your own, or you can purchase individual deflectors at any Evinrude/Johnson dealership at a somewhat higher cost.
Removing and installing them can be a hassle at times, but not always. I use a sharply pointed scribe with about 1/4" of the tip bent at a right angle whereas I can reach in, jab the tip sideways into the rubber, then yank it out. It's necessary to clean the seating surfaces where the ruber contacts the block with a small rat tail file to eliminate salt deposits etc. When installing the new rubber deflector, coat the deflector and the metal surfaces with WD40 which will act as lubrication to allow it to go in as easily as possible.
Make sure that you insert something into that deflector area before cutting and installing the deflectors if you make your own so that you will be certain that they are the right length and also that they will be seated properly. Usually a very small amount will be left extending about the block sealing area..... simply cut the excess off with a single edge razor blade.
bang4dabuck
OK I should compare my OEM NEW deflectors to the old ones as far as length and then cut to old ones (length).
What about cleaning the HEADS or just hit them with a wire brush ????
