Hello everyone. Question...1993 Mercruiser 260, water droplets on port side plugs, milky oil. After running port side riser is cool compared to starboard side. Could a bad manifold or riser gasket be the culprit? Or an improperly installed gasket?Thanks for viewing!
Those are some possibilities. So it is best to disassemble the riser/elbow and see if there is water in the inner chamber of the exhaust manifold. Be sure to drain down the manifold before disassembly
