woodman7975
- Aug 12, 2008
- 46
I have a 1988 Sea Ray Seville with a 4.3L Mercruiser. I noticed that whenever I put it in reverse and back it off the lift, or reverse in general my bilge fills up with water. It only seems to happen when I reverse, I can be on the water all day pulling tubers or drive around and I do not get any water in. I had a buddy drive while I lifted the cover and I can see it coming in when reversing, but I cannot tell from where. It looks like it is down towards the bottom of the outdrive, but I cannot really see so it could be from anywhere. I could see enough to verify that it is not coming from the drive shaft. I was able to inspect the outdrive as much as I could while it was on the lift and it looks like all the bellows except for the exhaust are in good shape and connected properly. The exhaust bellow does look old, but I could not find any noticeable tears. I was also told that water could not get in through the exhaust bellow, is that correct? Any suggestions on what to check next?
Also, I ran the engine in idle, forward and reverse while sitting on the lift and I did not get any water in. I also lowered it down enough to put the drain plug under water and it did not leak in through the drain plug.
