frederick Moody
- Jul 15, 2018
- 1
I have a 1987 Grady-White 24-foot offshore with a 350 Volvo Penta engine and a 290 outdrive twin prop. When I hook the water up to the outdrive to to run the engine I am getting more water back then I believe is going in the engine or heat exchanger the boat will overheat but when I pull the holes from the salt water pump it is dry. Is there something that can block the water from coming into the outdrive or do I just need to replace the impellers In The Raw water pump
