fbriggs
- Mar 30, 2017
- 24
Have a 1996 mercury (Tracker) 25hpEL, Sn# OG6309267.
Not use to the outflow restrictor streaming water and then stoping, then start again after 15-20 secs. But I think this is exactly how it's suppose to function since the tell tale hose comes directly out of the thermostat housing. So makes sense if would only flow while thermostat is open. Just use to working on a little bit newer engines.
Water temp around cylinders stats around 120 which to me is ok also. Hoping some older tech will confirm for me this is how these function. Thanks
