Water flow via bunny ears to exhaust
Howard Sterndrive
Re: Water flow via bunny ears to exhaust
looks fine to me...but if you went as far as the impeller, best to throw another one in for the $22, however greasing the spline is the most important part of going in there.
I noticed in another thread you mention using a 4.3 in place of the 3.8. Did you attach the OMC 3.8 manifolds to the 4.3?
Were there any valve cover clearance issues? tks.
prinler
Looks ok? Hmmm guess I'm just paridoid?
It was a flawless swap. Used same heads, manifolds, everything. The engine guy told me the difference in a 3.8 and 4.3 is like a 327 and a 350. Same same I think he said its a different crank.
boobie
Prinler, the water flow looks fine to me too.
Howard Sterndrive
it sure is a different crank, which is why you need a 4.3 distributor. It'll run with a 3.8 dizzy, but there's a chronic issue with ignition timing on 3 of the cylinders if you still have the IBM7014 distributor in it.
I am curious what the compression ratio is of a 4.3 with 3.8 heads.
The V8 equivalent head-wise would be a 5.7 and 5.0 (350 vs. 305) more than 327 vs 350, and you don't have to google very far to learn why 305 heads on a 350 won't work.
Maybe the builder took all of that into account, but I would have thought a piston swap would be necessary to make it all work reliably and make power.
prinler
When we built the engine he asked me what kind of gas I wanted to run in it. I said the lowest. Not trying to break any records! So low
Compression was his goal. Now I don't really know how that computes but when I did a compression check it was 120ish on each.
If I found 4.3l heads the exsaust manifolds would not fit. That's a huge expense! All I wanted was a 3.8 block but they are super rare on the west coats. All fwd car versions here. Red back east because of snow I guess.
Howard Sterndrive
ahh, well it sounds like he knew what he was doing then.. those 1985 2 pc rear main seal 4.3's are the real needle in the haystack out east
-good you found one.
prinler
Yeah, he even recommended a different torque curve with the cam and we got one custom ground CAM from back east. I went from a 15P to a 20P and i cant wait to see the difference! Im plagued by little things now like water getting into the upper and oil leaking out from the lower. :rolleyes:
