Hi! I'm looking for a little help. I was on the lake earlier in the week and it ran
well for about 15 min. came down to trolling speed and I heard it sputtering.
I tried to clean it out but it would bog down. I then pulled over and pulled the plugs.. top 2 looked brown with unburned fuel, middle 2 looked creamy gray and oozing on the plug threads, bottom 2 didn't look to bad. I was gearing up to
change exhaust gaskets. I pulled the powerhead this evening and noticed brown
foamy oil gunk around the shaft. The powerhead gasket was soggy and broke when the head was removed. The questions I have are: the foamy gunk on the shaft....is that caused from bad powerhead gasket or bottom endcap seals.
Also I replaced the exhaust manifold gaskets 5 years ago but failed to use
the epoxy on the bolts, instead I used an auto waterpump bolt prep. Thanks!
