water gushing out of 150txr exhaust relief holes
wildspeed
I noticed today a large amount of water gushing out of the 2 exhaust relief holes ( I think that's the name, square holes under the power head) on my 2001 2 stroke yamaha when cruising at higher speed. Should I be concern or is it normal, Thank you.
BaileysBoat
Re: water gushing out of 150txr exhaust relief holes
Normal. The faster you go the greater the exhaust volume and pressure. Going to seek the path of least resistance.
99yam40
Never noticed water gushing out of the exhaust idle relief holes, just a spray of water at idle.
Most exhaust pressure if normally dumped through the prop under way and I would believe that the water exiting the motor would go out there also
wildspeed
The water only gush at higher speed, only spit few drops and smoke when idling.
