1st time start with muffs on a 97 150 V-max. Been setting for about two years. Removed from boat that was dry sunk
- . Fired up no problems, but, no head pressure. Pulled the line off the top of the head. No water up there.<br />Changed water pump (correctly). Pee hole stream good. New thermostats (but, thats after the pressure port). Poppet valve okay. <br />With lower unit off, pressure from the inlet pushes water out the top (no restrictions from either direction). <br />When muffs are attatched to lower unit only (on bench).. You can see water coming out of the pump...and...lots coming out by the prop. Sumerging lower unit...runs cool with small amount (7lbs) of head pressure (benched/idle)<br />The question is...WHY can this engine not be run on muffs...seems to not get enough to the pump and most water flows out by the prop. Is this right?
