Smokey988
- Sep 7, 2019
- 40
I have a Gen 2 that has water in the u-joint bellow. A few months back I ended up with water in the sterndrive and had changed a few of the seals thinking I had solved the problem. When I originally took the drive off the boat I found water in the u-joint bellow but figured it was a leaky bell housing gasket that was letting water in. Last week while winterizing the boat I drained the gear lube and again it has started going milky. When I removed the sterndrive from the bellhousing I once again found water in u-joint bellow.
I went over the bellow very well to check for cracks and tears and even put a flashlight in to see if light was coming out anywhere. Nothing. The bellows were changed 2.5 years ago.
I did notice that the shift shaft where is goes thru the seal at the bellhousing is scored/pitted. Would this allow water into the u-joint bellow?
