Water in bilge - 2001 Seaswirl
chrishorn
I am noticing water in my bilge and have not had any rough and wet days out on the water. Other than the outdrive seal on my Volvo I/O, could there be any other common areas to check? and how would you even check the drive seals?<br /><br />Thanks for all comments..<br /><br />Chris
JRJ
Re: Water in bilge - 2001 Seaswirl
I get water from a leaky ice chest. Depending on the style of boat you have, there are other ways for rain or fog, even condinsation(sp) moisture to get in. Under windshield, thru hatch, bait box, etc. Good Luck
Mumblerone
How much water? Does you bilge pump take it out? Keep an eye on it! Just not familiar with Seaswirl. ;)
Capn Mike
I have a 23' Striper, and sometimes I'll get some water too. It always happens after a rain and while the boat is moored or parked. I believe mine is coming in through the hatch door which leads to the batteries....it's not sealed. Not enough to worry about.<br />Unfortunatly, we're not getting enough rain....can you send us some? It would appear El Nino is giving us S. Cal's lousy warm, sunny winter, and we need rain for the salmon!
Franki
Since fresh water does far more damage to wood then salt water, I make a pretty serious effort to keep it away from the stringers... (unless the seaswirl is one of the newer "woodless" designs.)<br /><br />at one point I couldn't stop fresh water getting in, so I poured half a bottle of salt down the gaps to soak in... (I was working on the boat at the time and had it all apart when it started raining).<br />(was a dumb idea, but seemed wise at the time and probably didn't hurt anything.)<br /><br />If there is wood down there, try and stop the leak...<br /><br />get a mate to put the host to it to simulate rain.. then go a searching see if you can find where its running down.. do you have inspection hatches?? <br /><br />I know nothing about yank boats.. my floor has hatches all over the joint.. so its easy enough to see at what point water is running down the inside of the hull...<br /><br />I got tired of blocking rainwater leaks in the deck hatches, so I put a tarp over it for now.. :) <br /><br />All I can think of for testing the seal, is to load up the front of the boat to lift out the stern enough to get the seal away from the water and let it sit, see if it still gets water in the bilge... (there is probably an easier way.)<br /><br />regards<br /><br />Franki
Capn Mike
There's wood in the Seaswirl cabin core, but not in the stringers or the bilge. That's why I don't worry about it.... :D
