I am a new boat owner. I have a 1999 Glastron GS185 w/ mercruiser 4.3L and Alpha1 gen II. I am in southeastern Alabama and the boat has only been used in fresh water. I just had new water impeller, new gimble bearing, new shift boot and new exhaust flappers 3-weeks ago, and boat in the water 4 times since. The mechanic I chose has an impeccable reputation and told me that the other boots and u-joint are in great shape. My problem is that I am still getting a little water in the bilge. The boat is a runabout bowrider that we will use for water sports when warmer. We are fishing alot with it right now and the water gets in bilge when engine not running, none when underway. The hull is in good shape and I am pretty sure the water leak is from either the transom and/or the transom plug. I am very skilled mechanically with cars and motorcycles, and after reading all of the great info on here believe the boat to be equally do it myself-able. Resetting the transom plug should be easy enough, but what kind of sealer? Three screws hold in the insert and 1/2" pipe thread plug. What about the small trail of water I have witnessed from the bottom of the starboard side of the transom plate(if this is what it is called)? It is the mercruiser transom.
