muskyfins
- Jun 7, 2012
- 580
Yep. I expect there to be water in the bilge. But not when she's on the hard!
2000 Rinker 270 FV-5.7L EFI-Bravo 3
Getting here ready to dunk this weekend I ran on the muffs for about 20 minutes before changing oil, and messing with sticky lower shift cable. Also wanted to make sure not going over temp, etc. Looked all around in the bilge/engine compartment and didn't notice anything. Sucked out oil and then went to run a few errands for about 2 hours. When I returned, I noticed the pavement was still wet but just under the drive. Upon further inspection, I noticed water dripping from the garboard fitting and then some water in the bilge. No way to tell how much may have been in there, but there wasn't much left. (12 ounces??)
So the inevitable question-what gives??
No water in oil. Will recheck tonight
Ran long enough that I don't think there was water in any cylinder, but if it was very minor, it might blow out the exhaust. Might get recheck done tonight, but might have to wait until weekend.
Cracked exterior water jacket only not affecting either of the above? (I hope not) :blue:
Leaking drain plug on motor or sea water pump clamp loose? (Please let it be something easy like this)
And yes, boat was properly winterized-drained fully, added 50/50 AF to lower water pump hose. And I don't recall it being below freezing much this winter anyway.
Anybody else care to guess?
