Re: Water in cylinder Johnson 88hp SPL
I not a expert on outboards but I think that the head gasket my be bad or you might have a warped head because from what i remember from my 15 hp engine when i replaced my head gasket. Water goes through the head to cool it and the gasket is what keeps the water out of cylinder. So there might not be a good seal there somewhere for that cylinder that has water in it. More likely a bad gasket because if you had a warped head there would be water in the others more than likely.
