I been working on a '83 90 hp inline 6 off and on for the llast 8 months. One problem led to another. Put a complete water pump in it and the base assembly did not seem to seal at the bottem. After completing the job the motor crank right up and it started peeing but I found water coming out the lower two spark plugs. Could the base assembly not sealing cause this or could it be the head gasket? Before this problem the compression showed 130-129 on all cylinder. I have not check the compression since this happened
